My computer is acting up! Like i said in another post, i have not installed any new crap in it, defraged, cleaned up HD, followed skyfxl's guide to stop non-crucial processes, and nothing!
When i play samples on VDJ the song playing pauses/stops for a fraction of a second.
I burned a CD using Nero and its skipping all over the place, i then burned a mix recorded with VDJ (burnt on nero) and it sound perfect no skips, but i cannot burn MP3s straight from my HD without skips.
What the hell is wrong with my laptop?
geposted Sat 17 Mar 07 @ 3:26 am
Any help would be greatly apreciated
geposted Sat 17 Mar 07 @ 8:25 pm
whats ur spec?
and have u runa bootime degrag recently if not check out
www.diskkeeper.com
www.diskkeeper.com
geposted Sat 17 Mar 07 @ 9:30 pm
that page is down
geposted Sun 18 Mar 07 @ 3:44 pm
this is the laptop i bought and i have not added/modified anything
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00214075&lc=en&cc=ca&dlc=en&product=423998&lang=en
geposted Sun 18 Mar 07 @ 3:46 pm
He probably meant to type:
http://www.diskeeper.com/defrag.asp
Diskeeper is a decent little program but in reality it's just a better version of M.S. Defrag with some cool features like bootime degrag.
I'm not a technician nor to I play one on TV but I think your laptop has issues far beyond a few fragmated files. If it were me and I could not get any free advice I'd do a fresh back up and then factory restore and take that laptop back to the day it was born.
Good Luck. :^)
Good Luck. :^)
geposted Sun 18 Mar 07 @ 5:26 pm
are you using microsoft windows? because everyone knows its realy bad and crashes and its villanous and evil and eats babies
geposted Sun 18 Mar 07 @ 7:25 pm
LOL!
I'm supposed to say that! =P
geposted Mon 19 Mar 07 @ 1:25 am
I Think i figured it out!
My External HD is supposed to be 7200RPM but a buddy of mine says its a posibility that my HD is screwed up, and not running at 7200RPM but at variable speeds causing the laptop to get confused, thats why when i burn mixes recorded with VDJ ( files wich stay on my laptop HD ) are perfectly ok when burned.
I bought a new HD and im trying it out, it seems that VDJ is not skipping anymore, so far so good.
I hope this helps anyone out there who might be having similar problems.
geposted Wed 21 Mar 07 @ 5:02 am
Windows Eats babies? That explains it. May the force be with us all.
geposted Wed 21 Mar 07 @ 5:08 am
