when i try to connect my laptop(toshiba tecra A7) with the console.a very noizy bzzzzzzz starts.if the laptop is not plugged and only works by the battery then no problem. one time that i faced that problem after some hours was fixed by itself.anybody had the same problem?or know how to fix it?
geposted Sat 17 Mar 07 @ 2:37 pm
It is a very common problem , laptops are not earthed so therefore you need a ground loop isolator for each channel , it connects between your sound card output and console, mixer,etc , this are available at most electronic retailers and only cost a few pounds .
geposted Sat 17 Mar 07 @ 4:48 pm
Or, just go to your local store and buy one of those adapters that are for a 3 prong plug into a 2 prong outlet. It it has a wire, cut it off, if it has a little tab, put some tape over it. I've been doing that for almost 15 years.
geposted Sat 17 Mar 07 @ 5:54 pm
thanks,solved it.i put some tape between the 2 prong of the plug and fixed.
geposted Sun 18 Mar 07 @ 3:50 pm
picture please on where to put the tape?
geposted Sun 18 Mar 07 @ 11:27 pm
Also, where does the adapter go exactly. Between wht two points of contact?
i.e., Between the strip and the wall, between the laptop and the strip, between the mixer and the wall, between the mixer and the strip, or some combination of these?
geposted Mon 19 Mar 07 @ 3:08 pm
this is where you put the tape and the poblem is fixed.
http://rapidshare.com/files/21964267/DSC00652.JPG.html
geposted Tue 20 Mar 07 @ 4:58 pm
