Topic: Laptops & Headphones?
Hi all, I am going to buy the pro version of this software.
Could you tell me what I need in order to use headphones properly with a laptop when Djing??
I take it I need a USB soundcard with two outputs??
So do I need a 4.1 a 5.1 etc or will either do or what else if anything?
Many Thanks
geposted Sun 18 Mar 07 @ 5:29 pm
4.1 sound card - > mixer -> head phones, is a common setup.
ok thanks. So can a 5.1 be used or does it have to be a 4.1?
yeah 5.1 works fine aswell,, 4.1 is minimum
