i all!!
back again with more problems
after lots of trouble a few months ago i got mt tcv set up working perfect
(this WOULD NOT OF WORKED WITHOUT THE HELP OF DJ IN NORWAY !!! THANK YOU)
before i go and buy the pro version i have set up a new pc with fresh copy of xpsp2
i have a maya44 pci sound card ( vdj keeps giving asio errors when i use the esi asio driver but with asio 4 all it works great.... but this is not my problem!!)
when i play (on both decks ) im getting a high pitched noise coming over the speakers ( same noise you get if you play a time code disk without virtual dj on ) this did not happen like this on my last set up but all the settings are the same... its earthed the same way... same mixer... the time code signal is 100%...
everything is working ok except for this whineing noise
please please help
im going mental trying to sort this out
thanks
dj jarvis
please please help
thanks
dj jarvis
geposted Sun 18 Mar 07 @ 9:13 pm
ok i have it sorted
on the esi maya driver the channel(s) were set to monitor not out.... not sure why this worked because im using the asio 4 all driver!!
but if it aint broke dont fix it
thanks everyone who posted a reply ( i.e NONE thanks a bunch)
geposted Sun 18 Mar 07 @ 10:35 pm
Might want to consider buying the software and stop using crack.
or if you've bought it legitimatly register it.
geposted Sun 18 Mar 07 @ 10:47 pm
odd noises over your sound can be one of the side effects of using a unoffical version check out the latest demo here
https://virtualdj.com/download.html
hope to see you with us soon
geposted Sun 18 Mar 07 @ 11:41 pm
