1. Do the timecoded vinyls work with the home edition?
2. using virtual dj, can i record my vinyls from my technics mkIIs onto my computer?
thanks alot :)
thanks alot :)
geposted Mon 19 Mar 07 @ 5:16 am
Hi,
according to this
it looks like it doesn't i'm afraid.
(maybe somebody could correct me if i'm wrong)
The professional edition version definitely does though, and comes with a seperate program called "rip-vinyl" that lets you record your records onto your computer by plugging in your turntable into an input socket on your sound card. (To get good results you really need to buy a decent sound card for your computer, the ones they come with as standard are normally pretty rubbish!)
Hope that helps you, and hopefully see you soon as a registered user!
Don't forget if you want to give it a try, you can easily download the trial version from the downloads section of the website.
according to this
geposted Mon 19 Mar 07 @ 2:21 pm
