Forum: Old versions
Topic: Green vertical stripe on Toshiba notebook display
I have a ew Tosiba Satellite notebook. dual core processor & 2gb ram. I keep getting a green stripe on one of the displays. Is something set up wrong or is the Tosiba video card unable to handle the load?
geposted Mon 19 Mar 07 @ 6:47 pm
sbangsPRO InfinityMember since 2004
is this full time ?
or just when u play a video
what make is ur graphics card and how large is it?
geposted Mon 19 Mar 07 @ 8:06 pm
This is usually caused by either not having hardware acceleration enabled OR having a graphics card that doesn't have hardware acceleration.
geposted Tue 20 Mar 07 @ 5:50 pm
i concir
geposted Tue 20 Mar 07 @ 11:12 pm
.. or bad codecs
geposted Wed 21 Mar 07 @ 12:30 am
I had the same problem on my dell. I spent hours trying to figure it out. I finally updated the Bios to the latest version and it solved the problem. I didnt need a new video card or anything else.
geposted Wed 21 Mar 07 @ 11:54 pm
You said Dell, what model #?? I hate Dell LOL
geposted Thu 22 Mar 07 @ 6:48 am
please dont swear lol ;) u said the Dword.
geposted Thu 22 Mar 07 @ 9:32 am
mzackPRO InfinityMember since 2006
So I take it that DELL computers are not that recomended? I have an XPS M140 and it works ok....but Im always looking at upgrading, any suggestions on a good notebook to run Video?
geposted Thu 22 Mar 07 @ 5:23 pm
Build a system, you won't be sorry and it will probably be cheaper. It isnt as difficult as it sounds. I am piecing a new system together slowly myself. I am impatient and want it done right away, but cant afford it right now.
geposted Sat 24 Mar 07 @ 12:14 am
For now, turn OFF hardware acceleration. Only thing is, you won't be able to use effects for the fade. It will still "fade", but not with the fancy schmancy graphics...
geposted Sat 24 Mar 07 @ 12:53 am
