I like to pull 15 or more songs for my cocktail and dinner music and set it up to cross fade on it's own. Both of my computers started developing the same problem: Ater the 3rd or fouth song it starts out fine than jumps 30 or 40 seconds into the song for no reason (no cue points set up). By the 5th or 6th song it starts jumping further into the song. I have not changed my settings and have plenty of memory (never had this problem with earlier versions). Is anyone else having the same problems? I need it fixed fast it has cause me way to many problems at Weddings.
Help!
Help!
geposted Tue 20 Mar 07 @ 1:30 am
Try this --
- on the Sound Card - Latency :: set to AUTO
- make sure the Safe Mode is UNCHECKED
- And below that in the SCRATCH set it to QUALITY and SIMPLE ALGORITHM
And make sure your DirectX is up-to-date ::
Minimum with - Dec 2006
http://www.microsoft.com/downloads/details.aspx?FamilyId=77BC0499-19D0-46B6-A178-033D9E6C626B&displaylang=en
Or the latest - Feb 2007
http://www.microsoft.com/downloads/details.aspx?FamilyID=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&displaylang=en
geposted Tue 20 Mar 07 @ 4:33 am
