Hi every body
the HDD is a seagate 500GB external with a ICY case using this since 6 month without probs but:
laptop is Fujisu amilo 350
well running virtual DJ for 3 years without any probs / last saturday what a surprise:
i normally erase the mp3 database due to changes and updates of MP3s / when i hooked up my 500 GB external drive to the computer all was normal / harware detected installed and can be used now / so far so good / then i started Virtual DJ in the club I am playing (version 4.0) / due to his missing database he ask me if he can look through the harddrives for mp3s / and off the process went almost half way through we had the message
runtime error R6025 pure virtual fuction which shuts down the program
I did not play around very long and got my laptop out / used the same external had drive and experienced the same problem / well the browser in Virtual dj was working but I had no search function / what a pain in the a.... / but we went pretty good round the night (06hrs playing) /
Back home on sunday and monday i tried my friends Virtual dj (version 3.4) on his machine with the same HDD same again / all reported message came / when scanning drive c, d , e om my computer or any other external drive all fine / so iscanned the drive with anvira security suite and Ad-Aware SE Personal and ashampoo anti spy ware all clean as a baby bum /
so three diff machines three diff versions of Virtual DJ but all show the same prob
what i do now i will transfer all mp3s to a new hadd and format the one who gave trouble / see what happens
in case any one has a clou drop me a line
thanks folks greetings from germany
geposted Tue 20 Mar 07 @ 7:44 am
please use a legal copy of pro it will relive these odd bugs caused by using cracked editions
hope to see you with us soon :)
geposted Tue 20 Mar 07 @ 2:38 pm
what is the RPM Speed of your drive?
there is no hard ware attached to the program / the speed i am using is 45rpm
geposted Thu 22 Mar 07 @ 8:29 am
just to clearify the vip kayles words / i thought here are no pirates on board this site ???? /
well my two copies are shop bought in germany / a bit cheaper than in the UK ( 29.99 EURO ) /
yesterday i bought the home edition 2006 which is version 3.4 in german how lovely / and with the old EXT HDD still with reloading the new prog the same problem / anyway we are not talking here with any pirated cracked stuff / its the real thing
so to give you a clue to this runtime error is from mircosoft visual C++ / MS knows about this problem / you can read on MS homepage
http://support.microsoft.com/kb/125749
Article ident number 125749
3 pages explain why and what
this problem is also briefly explained in the C++ vers 3.0 readme.wri file (short description)
so i did what i previously said / i copied bit per bit to a brand new EXT HDD seagate 500GB / well folks what a surprise it works no runtime error / the only i noted is that when the program completes the mp3 EXT HDD scan it automatically minimises / drops to the task bar but is not shutting down /
so what is left to do /
i got a new machine yesterday / intel duo core pcocessor and a lot of hi end stuff inside / try to make it running to day / the when all is up i try the old EXT HDD and see what is happening /
keep you all updated / i will pobably format the beast (old ext hdd) later
thanks for listening
rgds yogi from germany
geposted Thu 22 Mar 07 @ 8:53 am
