Can i have my maya44usb outputs to only output Phono signal ?
I want to use my phono inputs on my mixer with the VDJ/TC only.
I know it is a plug in for the software to do that, but that is an FX plugin and i have to turn it on everytime when i start the software. (may be it is a way to have it on all the time from the registery ?
geposted Tue 20 Mar 07 @ 5:58 pm
I'm pretty sure you can't do this. But I know of a way around this....just hook up y's to the output of your turntable. One set set will go to the maya & the other to your mixer. Then you have the ability to switch to phono or line.
geposted Tue 20 Mar 07 @ 7:38 pm
Yeah i know, but i don't want to take over the lines inputs i need line inputs for something else. I just want to use the maya on the phono inputs.
geposted Tue 20 Mar 07 @ 8:28 pm
whats your goal?
geposted Wed 21 Mar 07 @ 12:27 am
think there's a sound effect to do what you want. :)
geposted Wed 21 Mar 07 @ 11:24 am
funkturnal wrote :
whats your goal?
... need line inputs for something else. I just want to use the maya on the phono inputs.
geposted Wed 21 Mar 07 @ 12:46 pm
hmm...read the first post.
geposted Wed 21 Mar 07 @ 12:48 pm
D'oh! sorry! Not sure there's a way, but have you tried lowering the maya's output volume to a very low setting, or is that still too loud?
geposted Thu 22 Mar 07 @ 4:44 pm
ohhh....yes u can do this. You need a line to phono converter. I used to use this on one of my boards.
http://www.esdl.co.uk/body/invriaa/invriaa.htm
make sure its line to phono not phono to line....they don't work backwards.
geposted Thu 22 Mar 07 @ 5:43 pm
