Forum: VirtualDJ Skins
Topic: @dj fandos - V-BCD 2007
Dear Dj fandos thanks foryour latest submitions
i have published them all here
http://www.virtualdj.com/addons/skin.html?id=2783
however one of them has a small error which prohibits it from running
V-BCD 2007 - para bcd, mejorada y con video
it has an xml error on line 12 please could you check this and then i will be able to publish it for you aslo
Thanks :) have a nice day
geposted Wed 21 Mar 07 @ 2:00 pm
Nothing for the 1024x768 users???
these new skins are very complex :) (well done on that) and it would not be possible to fit the same features and intracasy into a smaller size skin
i presume this is why :)
Video BCD2000 : 1280x 1024 and 1280 x 800
seems like the .exe file don´t install the skin . Rename it to .zip and copy it to the the skin directory
this will not work .
the file is an installer and wont be read as a zip
if it wont install this is because virtual dj may be installed in a non standard folder.
strange . it worked for me on 2 different computer with standard folder . but i needed to rename .exe to .zip
V-BCD_2007.zip 1280x800 work in my computer but there isn't drop zone to load song from browser.
doh!
have unpublished this one until this bug is tested/removed. by the author sorry folks .
I must say I see 110% Improvement Yo, Keep the good werk up...
