Since there are quite a few choices of hardware, I was wondering which is better?
Using timecoded vinyl (need turntables)
Using timecoded cd (need good cd players)
OR
the xp10, mk2 or dj control mp3
I want to mix hip/hop, techno and also play videos.
OR
geposted Wed 21 Mar 07 @ 6:00 pm
have you checked out skyfxl's ultimate guide to controllers ? i might get xp10s but i've also considered the high end dvd player w/ the preview screen....can't remember the make er model.......
lots of ppl like the mk2......kinda small control surfaces
geposted Thu 22 Mar 07 @ 4:40 pm
I like the Mk2, but sometimes I forget that I have it in scratch mode and go to do something... zzziiiip
however, I still like to versitility / and budget
geposted Thu 22 Mar 07 @ 6:46 pm
I must have missed skyfxl's references. Where is the link? Thanks
geposted Thu 22 Mar 07 @ 9:30 pm
check around i don't have it at my fingertips, but it's right here....probably his blog
geposted Thu 22 Mar 07 @ 10:01 pm
i used to have a denon 5000..... the high end cd players are only a little more than the xp10's......if your system crashed you can still play and scratch.........
geposted Fri 23 Mar 07 @ 3:23 am
ICDX.... Rocks... give you everything the highend CD players give
and its a direct controller which works very well even for scratching.
geposted Fri 23 Mar 07 @ 4:09 am
geposted Fri 23 Mar 07 @ 12:27 pm
this is my favorite
http://www.m-audio.com/products/en_us/TorqXponent-main.html
geposted Wed 11 Apr 07 @ 3:32 am
i like the xponent aslo might get it in the summer :)
geposted Wed 11 Apr 07 @ 6:56 pm
have anyone sucessfully tried the cdn 25 from numak with timecoded cds? i cant seem to get mine to work.
geposted Tue 17 Apr 07 @ 1:50 am
