Is there any difference in the software? Except for the pictures of the turntables!
geposted Wed 21 Mar 07 @ 8:33 pm
there are many very significant differences:
- Different decks in skin
- Different box when purchased
- Different logo on top of skin
- Different splash screen
- Different install folder
- Different tray icon
So dont come here say they are the same
Just kidding ;) hehe...
VDJ & Numark CUE is same, just different branded
geposted Wed 21 Mar 07 @ 9:01 pm
hehe
geposted Wed 21 Mar 07 @ 10:23 pm
ok here is another question:
can you connect on CUE the hardware wich you connect on VDJ i mean dac3 ,bcd2000,hercules dj console, midi controllers , etc or you can use only numark's hardware?
geposted Thu 22 Mar 07 @ 11:00 am
it will use any thing vdj can :)
its the same software with a numark sticker.
geposted Thu 22 Mar 07 @ 11:57 am
Can VDJ with default skin do as much as VDJ with Vmix skin can? OF COURSE =)
Cue is just another skin, it's exactly the same. ;)
geposted Thu 22 Mar 07 @ 1:54 pm
