Forum: Old versions
Topic: ssl sound card
can you use the serato sound card with vdj
geposted Wed 21 Mar 07 @ 10:48 pm
No, stamps are different they can work but they are not 100% compatibles, so some vdj's functions may not work.
geposted Thu 22 Mar 07 @ 8:47 pm
Hi,
I don't have one, so I'm not totally sure. But I thought that the sound card works perfectly, it's just the time coded vinyls that don't work very well.. so you'd probably want to buy some virtual dj vinyl for them.
geposted Fri 23 Mar 07 @ 10:47 am
Yes it's true, I got confused I thought you were talking about the timecoded vinyl, andytaylor125 is right I guess that serato must use a sound card that supports asio drivers so there's no problem in using it with vdj.
geposted Fri 23 Mar 07 @ 5:20 pm
ok saludos amigo
www.djnico.com.ar
geposted Mon 26 Mar 07 @ 8:31 pm
