Forum: Old versions
Topic: Video Output
ukdjdazPRO InfinityMember since 2007
Hello everyone, I have downloaded the trail version of VDJ, I have a small problem, I am trying to link the Video Window to my plazma, the problem i am having is when i connect the laptop to the tv THU S VIDEO it is only showing the over all windows and not whats in the small video window, I have looked in config/video and it just says window in the drop down menu, Im just wondering if i need to change any settings in my windows options, My grafix card is ati radeon express,
Like i mentioned im getting output to tv but its the overall view and not whats in the preview box on VDJ
help is required xxx
Darren
geposted Thu 22 Mar 07 @ 9:14 am
PionaraPRO InfinityMember since 2004
Hi Darren...welcome to VDJ!!!
Ok...first up, you need to make sure your external source is connected to your laptop before you power up.
Then, go into Control Panel>Display>Properties and make sure the second monitor is attached. To do this, go into the settings menu. You should see two monitors there. Right click on the second monitor and click 'Attached'. *Note - you may also need to select 'Extend my windows desktop to this monitor*
Then - boot up VDJ. Do not do this before you have attached your secondary monitor. Go into the config panel and go to Video. Click 'activate' and from the drop down box that appears, select your graphics card as opposed to window. Change the skin to 'Full Video' - makes it a bit easier to see what's going on.
Hey presto!!! You should have video!!! This is providing of course your laptop has dual outputs on the graphics...:o)
Good luck!
P
geposted Thu 22 Mar 07 @ 1:20 pm
Yeyyy all sorted thanks for your help
djdaz x
geposted Thu 22 Mar 07 @ 9:45 pm
