I've been using vdj for a good while now but the problem is, i only want to use the headphone and mix NOT with the speakers but at the same time i want to be able to hear it through the speakers. I only have in one soundcard (Nvidia) and its working fine but whenever i'm mixng and i plug on the speakers i can hear what i doing on the other deck (like messing with it) even when the crossfader is on the other side, i still hearing both side. What i want? is to be able to split it in a way that you only hear what i playing in the active deck through the speakers. Can someone help me please? :)
geposted Fri 23 Mar 07 @ 8:55 am
i have that same problem as well ... but my soundcard is and onboard and i have tried alot of options ... and they are not working still
geposted Sat 24 Mar 07 @ 6:29 am
You both need the Professional version of VDJ. It will allow you to easily split the signal.
OO
OO
geposted Sun 25 Mar 07 @ 3:42 pm
