Forum: Old versions
Topic: vdj play settings
hi to all, ive got vdj mk2 up an nearly running on vista,got the decks on pc screen, selected the track ,it cues up but it does not play the tune.Any advise on settings with hercules sound card or vdj settings?
or just general advise on the best running options.
thanks
glen(a new user)
geposted Sat 24 Mar 07 @ 6:11 pm
Does the Box for the MK2 say it is Vista Compatible? If not, try downloading the VDJ Software update(can be found when you login to VDJ.com in the Download Center) and the Hercules Driver update for Vista(can be found at http://www.hercules.com). -- If it's already Vista compatible, check your Sound Config.
https://virtualdj.com/update.html
grab the vista software.
and the vista driver
ftp://ftp.hercules.com/pub/webupdate/DJMk2/2007_CMK2_1.exe
make sure you install as admin.
