i conected my old dj console mk1 just to do some tests.
so i installed the latest drivers for mk1 wich hercules named them 2007
and after that when i close virtual dj i receive the next message wich is named as
"bridgedjwindowname:virtual dj.exe-application error" and it says the folowing "
THE INSTRUCTION AT "0x10004282" REFERED MEMORY AT "0x10004282" THE MEMORY COULD NOT BE "READ"
CLICK OK TO TERMINATE PROGRAM
CLICK CANCEL TO DEBAG PROGRAM
so i thought that reinstalling the software and the drivers of my soundcards (u46dj and hercules djconsole mk1)would give a sollution.
but i was wrong the same message comes again and again each time i close vdj.
please help.
please help.
geposted Sun 25 Mar 07 @ 6:11 pm
unless you are using vista i recommend you use the 2006 driver package
ftp://ftp.hercules.com/pub/webupdate/DJMk2/2006_CMK2_1.exe
geposted Sun 25 Mar 07 @ 8:04 pm
i dont use vista but with 2006 drivers i get an error directx drivers
i tryied to unistall dj console also but the same message continued to appear when i close vdj
geposted Sun 25 Mar 07 @ 10:43 pm
Utiliserais-tu par hasard mon DJC mapper avec les drivers 2006 ?
geposted Sun 25 Mar 07 @ 11:06 pm
i think that you ask me if i have download your mapper for dj console?
well the answer is yes
geposted Sun 25 Mar 07 @ 11:33 pm
so maybe it's the bug there was with 2006 drivers when using my mapper. Try with 2007 drivers (the bug was corrected)
geposted Mon 26 Mar 07 @ 1:06 am
As i wrote at the first topic i installed the 2007 drivers and then it started to show me that message.
But djcel i want to ask you something:
why even i have reinstall vdj and i haven't install your mapper either djconsoles drivers again the message appeard again?
ps: thanks for your quick response :)
geposted Mon 26 Mar 07 @ 10:10 am
It's a problem linked to the new drivers apparently :-(
We are investigating
geposted Mon 26 Mar 07 @ 3:29 pm
after alot of clean reinstallations i beleive that its the drivers that causes the problem and not your mapper.
thanks anyway:)
thanks anyway:)
geposted Tue 27 Mar 07 @ 12:53 pm
