Hi,
I've got a buddy using one of these and we can't get the headphones to monitor Deck 1 or Deck 2 of VDJ...
Everything else seems to work fine...
Are we missing something?
Thanks,
DJ TAO :)
Thanks,
DJ TAO :)
geposted Mon 26 Mar 07 @ 6:26 am
choose
inputs : none
outputs : headphones
card : mk2 dj console.
channels
1/2 main 3/4 heaphone.
should now work :)
inputs : none
channels
should now work :)
geposted Mon 26 Mar 07 @ 12:05 pm
Thanks SKYFXL,
We'll give it a go and let you know...
Thanks again,
DJ TAO :)
Thanks again,
DJ TAO :)
geposted Mon 26 Mar 07 @ 7:30 pm
geposted Tue 27 Mar 07 @ 12:09 pm
PDNMUSIC,
Thanks you so much...
DJ TAO :)
DJ TAO :)
geposted Tue 27 Mar 07 @ 5:51 pm
Hi,
I've got the same problem but this doesn't fix it. Anything else I can try?
Thanks
Thanks
geposted Tue 03 Apr 07 @ 8:47 pm
are you using the latest drivers?
geposted Tue 03 Apr 07 @ 9:57 pm
Hi,
Yes, I'm using your trial version of the latest version of virtual dj - and the latest hercules MKII drivers from their website.
Thanks in advance for any help
Ian
Ian
geposted Wed 04 Apr 07 @ 10:14 pm
ok so you have it like this
inputs : none
channels
if this fails try 1/2 headphones 3/4 main
remember to plug the speakers into outputs 3/4 if you choose this
inputs : none
channels
geposted Wed 04 Apr 07 @ 10:23 pm
Hi,
I tried what you said. It's behaving funny. When i tried 1/2headphones 3/4main i didn't have to plug the speakers into output 3/4. Also when in this state switching the headphone switch between decks A and B actually changes which deck is played through the speakers.
Was just playing about though and found that on the Hercules box I hadn't switched to ASIO drivers. Once you do that you get n extra option on vitrual dj which is to choose the ASIO driver as the sound card. This fixes the problem for me!
Although now, when I change the bass, middle or treble Ican't hear it in the headphones. I could in the previous version. The new virtual DJ supports that doesn't it?
Thanks for you help
Thanks for you help
geposted Wed 04 Apr 07 @ 11:00 pm
I cannot choose "mk2 dj console" as "card" at "setting" on my MacBook.
I have installed driver again.
What should I do?
What should I do?
geposted Sat 07 Apr 07 @ 11:38 am
Try 4.1 setup, is the same
geposted Sat 07 Apr 07 @ 1:00 pm
thanx!
as I choose "4.1", i can monitor.
geposted Sun 08 Apr 07 @ 1:14 pm
