Forum: Old versions
Topic: XP10 Setup
Just got 2 XP10's and a numark1050 ... v exciting but ....
I'm having problems getting the config right.
Installed the drivers for the XP10's, and they can control VDJ ok.
I've attached both to CH1 PHONO & CH2 PHONO respectivley.....( I thought this would have been line ..... sorry ... my first "real" mixer!)
I've enabled the XP 10 in the Remote control, and checked swap (so they are left and right as they should be ... at least that's what I think that's for!)
My mixer has a cross fader for the CUE but one channel is much louder than the other.
I'm still struggling with the settings for Sound Setup .... should they both be set to USB speakers.
Help!!! :-)
geposted Wed 28 Mar 07 @ 12:20 am
The XP10 sound cards are identifed by windows XP ans USB speakers so if you have 2 XP10s you should have 2 USB speakers in your audio tab of the Sound and Audio devices properties. You need to manually adjust the volume of the XP10s
Start> Control Panel> Sound and audio devices
Select the audio tab
Under sound playback, select the first usb speaker and click on the volume button below it.
The volume control window will pop up.
Adjust the volume to you desired level and close the window.
Go back to the Sound and Audio devices window, select the second USB speaker and do the same process.
After you finish, you can select your default device again and click on OK or just click on cancel. It will keep the settings you made for the usb speakers and still keep you initial default device.
Hope it hepls out.
Remember to register your XP10 to get you new Medal Of Honor!
geposted Thu 29 Mar 07 @ 4:13 pm
