Forum: Old versions
Topic: Pitch still reset in v 4.3
Hi,
even if the staff tell me that they will fix the pitch reset problem in the next release when switching the TCV control from deck 1 to deck2 when using only one turntable, the problem is still there in release 4.3. I am waiting for that fix since 4.0. When can we expect to have that problem fixed???????????? I like that product but please instead of developping new feature please fix your core features, people will have a better satisfaction and you will sell more otherwise we may finish by switching to another product.
geposted Wed 28 Mar 07 @ 7:51 pm
its as stupid as the time code running out problem and they managed to fix that one (one of the only changes as far as i could see)
hey
It was fixed in the last version, you need to click the other deck not turn the tcv control off.
Hi Dj Cyder,
it is not fixed. You can try it, if you get it working then show me how. An analyst said that it was not fixed in 4.2. I was thinking to get the fix in 4.3 but it is still not there. If for any reason it was fixed, in single TCV mode the control is exclusive so when you activate the deck 2 it deactivate the deck 1 which makes sense.
Thanks
that isn't the way it works. Say timecode its active on deck a, and you want to change to time control on deck B, then you click the tcv button on deck B not turn off A's button. It only works when VDJ is in single time code mode.
Hi,
have you ever tryied it? I'm using it and in single TCV if deck 1 is active on TCV when you click on TCV of deck 2 it will automatically deactivate TCV of deck 1. I have nothing say against that that is the way it works and it is the way it must work. However the pitch should remain to its last value when the TCV control is removed.
Worst case, let assume the coder did it the way you are saying, what would be the benefit of keeping both active at the same time and then deactivate the first one? You don't care at the end all you want is the code to retain the last assigned pitch value to the deck through the TCV.
If you find a way to make it work, (after having tryied it) then let me know I'll be really happy to finally have it working.
Thanks
