Hello, I need to know the exact value that I have to use to control the off and on posittions from the fx1,fx2,fx3.
I don´t have any problem when I do it with the keyboard.
( deck 1 = F1 . Value +1 .... ) but with my UC33 it doesn´t works.
I need to know this deck 1 fx1 =midi 21 value??
deck 1 fx2 =midi22 value??
deck 1 fx3 =midi23 value??
Could anybody help me, please?? Thank you.
geposted Tue 07 Sep 04 @ 9:25 pm
What exactly are you trying to do with the UC33. I have one and no problems here.At least after reading the instructions I got it to work with VirtualDj no problems what so ever.
geposted Wed 08 Sep 04 @ 12:57 pm
Ok, I need know the value in vdj configuration and midi value in uc33(any preset?)
example for fx on/off in desk1.
Key:midi 18 on desk1 value: +1
Key:midi 19 on desk1 value: +2
Key:midi 20 on desk1 value: +3
example for fx on/off in desk2.
Key:midi 21 on desk2 value: +1
Key:midi 22 on desk2 value: +2
Key:midi 23 on desk2 value: +3
Help me please . Thxssss ¡¡¡¡
geposted Wed 08 Sep 04 @ 4:57 pm
You need to read the instructions that came with the uc33c . Use preset 33 it is the one I am using. If you cant make it work your doing something wrong.
geposted Fri 10 Sep 04 @ 1:55 pm
Ok man ¡¡¡ all it´s good now. thxs ggggg
geposted Sat 11 Sep 04 @ 7:11 am
could u tell me pleaze, how u sold that problem? i have the same and if u used preset 33 (see above), which channels u used?
geposted Sat 06 Aug 05 @ 1:46 pm
First set your preset to 33 . Then go into setup and activate the midi controller setting. Then go into the keyboard short cuts and start assigning functions for your uc33c.
geposted Sat 06 Aug 05 @ 2:49 pm
