Forum: Old versions
Topic: Advice on purchasing a Soundcard for PC
Whatr is the standard for VDJ pragram??
geposted Thu 29 Mar 07 @ 12:26 am
numark virtual vinyl
delta44 works great aswell = pci
maya44 = usb
creative soundblaster live 24 bit external works for me and it's only $50 at circuit city.
I have the M-Audio Delta 410 in all of my rackmount PC's. they are fantastic
I bought that at Argos - you can even put vinyl singles and LPs - and even cassettes - in there. It also has an "Audio Clean-Up", to eliminate the "frying bacon" effect from vinyl and the hiss you get from tapes. Record the tapes with the Dolby off and use that one - it sounds muffled otherwise. You can even put the tapes into Virtual DJ and split the tracks and even make them stop and start in the right place, so you don't have long gaps.
