Hi, I work with Virutal DJand I've some problem with my old sound cards and had to switch by new ones, so I got two identical sound cards (Sound Blaster somehing), but when i try to configure the software to use two sound cards I don't have the option, I can only select One sound card, externa mixer and 4.1 sound card, the both cards are working perfectly and drivers / windows update are ok too. I'm using version 4.2
Thanks!
Thanks!
geposted Thu 29 Mar 07 @ 5:00 pm
If you are using a licensed copy then enter your serial here - https://virtualdj.com/fusers/modifuser.html
Pretty sure the trial version only supports one soundcard.
geposted Fri 30 Mar 07 @ 4:18 am
I had a problem with two soundcards with VDJ 3.4 - it's a conflict of some sort - I tryed to set up 2 identical soundblasters, And no go at all.
try two DIFFERENT manufactureer sound cards.
geposted Fri 30 Mar 07 @ 11:36 am
Ok, I know that with two diff. sound cards it work, but I need it to work with two identical sound cards. It looks like the Virtual DJ just look for different names on the windows device list instead of looking for all sound devices installed on the PC. I tried to rename my device and i've done it, but i needed to edit the inf driver files and the card stoped playing sounds after that, but the Virtual DJ detected 2 sound cards.
geposted Fri 30 Mar 07 @ 1:34 pm
I had that problem long time ago, what you should do is to create a new root in order to work the drivers separately it should work otherwise you have to edit the registry to break them.
geposted Fri 30 Mar 07 @ 9:34 pm
