I got some problems with the installing and uninstalling from my hercules dj console.
In the beginning there were no problems at all.
After using it with WIN XP I saw on the internet a driver update.
I´ve downloaded it and tried to install it. The only thing he does is repeating the uninstaller program. Even after a restart he stops and doesn´t run the install program .
But and that’s even worse now my dj console doesn't work anymore at all. I´ve already tried to install the old driver with no success.
I've look around in the register and tried to remove every little thing what has to do with the Hercules console
And still whit out success
What is the solution for this problem ?
Please i don't wanna reinstall XP
geposted Thu 29 Mar 07 @ 11:26 pm
Check last driver version https://virtualdj.com/forums/66083/Hardware_Technical_Support/Common_Device_Drivers___Updated_last_on_25_3_07.html and if you don't solve your problem contact Hercules Service Support http://ts.hercules.com/eng/index.php
geposted Fri 30 Mar 07 @ 8:35 am
- Hi I experience the problems with the new driver...
So if you have contact with hercules please let us know what they say...
peace
peace
geposted Fri 30 Mar 07 @ 10:09 am
Noop it still doesn't work
Hopefully Itried it but as say without any succes anybody else an solution??
geposted Sat 31 Mar 07 @ 7:46 pm
You can only contact Hercules Service Support http://ts.hercules.com/eng/index.php
geposted Sun 01 Apr 07 @ 2:42 pm
