i have 2 stanton st 100s, they dont have an ground screw. where should i ground them? is this why anti skip doesnt work? when i pick up needle song stops. can someone dierct me to a link to help me.
geposted Fri 30 Mar 07 @ 4:19 pm
Turntables' ground should go attached to the pc gabinet not to the mixer.
geposted Fri 30 Mar 07 @ 9:25 pm
the reason you dont have ground wires on your turntables is that your tts have line outputs and not phono output.(they have an internall preamp fuction)
in time coded gonfiq unselect preamp fuction.
geposted Sat 31 Mar 07 @ 10:44 am
So then maybe you need to select cd instead of vynil.
geposted Mon 02 Apr 07 @ 6:12 pm
No.stay on vinyl mode. You just unselect pre-amp fuction and select smart mode so the song song dont stops when you pick up the needle
geposted Tue 03 Apr 07 @ 11:57 am
