I just got my MAYA 44 soundcard, I installe dthe drivers (I think)....I can see it in the sound set up, it says MAYA44 Usb and it shows a picture of it.
When I start to play my TCV and hit auto config it says "No Timecode Found".......What am I doing wrong?
geposted Sat 31 Mar 07 @ 1:04 am
1st you should go to the sound setup again
select timecode in the inputs menu
then go to soundcards and select asio drivers
and try again ... playing your tcv ...
hope this helped
cheers,
matt
p.s.: remember do not change the usb port after you installed maya
the card only works with the port you installed the drivers with
so, if you changed the port, you have to install the drivers again
hope this helped
cheers,
matt
geposted Sat 31 Mar 07 @ 1:23 am
Ok...here are my settings in 4.3:
Inputs - two time codes shown
outputs - external mixer shown
Soundcard(s) - ASIO Driver
Asio Driver - MAYA44Usb ASIO Driver
Input Channels - Channel 1/2 Left Channel 3/4 Right
Output Channels - Left Deck Channel 1/2 Right Deck Channel 3/4
......whenI click on timecode config, there is "0" timecode quality....whenI press advaced view and "Auto Select" it says no timecode found
geposted Sat 31 Mar 07 @ 1:31 am
please, go to the window's device manager and tell me where your maya usb soundcard is listed ?
is it under the usb tab telling you also the version(2.5.5) of the driver ?
or, is it listed below sound, video ... ?
if it's listed under usb the drivers are installed alright
if not, reinstall them
how did you connect the soundcard with the turntables and the mixer ?
almost forgot...
you also have to change some settings for the maya usb soundcard
you will also find a lot of help when you go to the blogs page and make a search for maya 44 (usb)
here are a couple,
https://virtualdj.com/blog/DjRudy78/blog2887.html
https://virtualdj.com/blog/coronaextra/blog1335.html
almost forgot...
here are a couple,
geposted Sat 31 Mar 07 @ 1:39 am
..ok, I see it under "sound, video and game controllers".....it says (Audio Device on USB Bus V2.5.0)
geposted Sat 31 Mar 07 @ 1:49 am
gotta reinstall the drivers
btw, get some new ones here
https://virtualdj.com/addons/view.html?type=tool
your's(2.5.0) are old
geposted Sat 31 Mar 07 @ 1:53 am
Thanks......ok, where do I put them once I download them.......I saw them download and then I saw a quick flash, like a windows default warning.......it opened up in my WINRAR....Im not too familiar with this whole zip and unzip thing......
I wish I was a little more computer literate.......I guess it takes practice...I did get my TCV decks to move with the TCV records....thats a start....LOL!!
geposted Sat 31 Mar 07 @ 1:59 am
"unzip" the drivers in a temporary folder
and run the setupXP2k.exe file (you're running win XP, right ?) inside that folder
geposted Sat 31 Mar 07 @ 2:04 am
I cant seem to find it to unzip.....it downloaded ok, but whenit was done it dissapeared, Im still looking...
DUDE.....Your the best...can I send you some money!!
geposted Sat 31 Mar 07 @ 2:07 am
after you reinstalled the drivers
you have to configure the card
check this,
https://virtualdj.com/blog/cstoll/blog1116.html
you can access the panel in the sound setup
in the newer versions, like you have ....
check this,
geposted Sat 31 Mar 07 @ 2:10 am
well... download the file one more time
if you click on the link a small window will open up
where you can decide where to put the file
remember that folder
or simply just hit open after you clicked the link
money ?
naaaah...
just returning favors...
thanx though ;-)
geposted Sat 31 Mar 07 @ 2:14 am
All set and spinning.....this is nice, faster than the MK2
Thanks Again....:)
Thanks Again....:)
geposted Sat 31 Mar 07 @ 2:22 am
cooool
have fun !!!
have fun !!!
geposted Sat 31 Mar 07 @ 2:23 am
where did you bought tcv ? why my dreams cant come true ;[[ its 2 weeks they are out
geposted Sun 01 Apr 07 @ 1:47 pm
I got mine here on VDJ website....took about 2 weeks to deliver.
geposted Mon 02 Apr 07 @ 3:13 am
but they are already two weeks out of stock ;[
geposted Mon 02 Apr 07 @ 10:56 am
