Topic: 1 cd player/turntable use in VDJ
Can someone tell me how to configure VDJ when only one CD-Player/turntable is in use? In the options i still must configure the left and the right dec. There is no way to configure only one player for both decs.
geposted Thu 09 Sep 04 @ 12:37 pm
I think it's not possible.
There should be a possibility with deck selection, like with the XP10's, but this will require a new update/version of vdj.
I think so, too. But in the description of vinyl with timecode they say it will work with "one or two turntables". It still would work if they make the coice whether a dirct dec or the active dec.
If you had XP10 or Hercules DJ Console you could configure the line in so you could plug an external CD Player to it...2 decks on screen and 1 External CD....if that's what you mean?
Well if there gonna do this i think it would be great to make the program modular? add on turntables -2 real decks 6 virtual ones? Peace
XP10 doesn't have a line in.
