My software "forgets" the info after the track has been scanned. As long as the program is open it remember it. but if I close it, when I reopen it the tracks apear unscanned. but only on recently added tracks. It remembers all the tracks that were on my machine when I sid the install and the first scan.
any ideas?
any ideas?
geposted Mon 02 Apr 07 @ 9:57 am
The same thing happens to me, even when the program stays open, if you move to another folder and come back to the newly scanned one, it seems to remember some, but not all scanned files?
This is also a bug and needs to be fixed. C'mon dev team, let's attempt to fix these things that are obvious bugs and get the program working as advertised!
geposted Mon 02 Apr 07 @ 3:40 pm
Try setting "WRITE VDJ TAGS" to enable and disabling the ID3 tags. Also, make sure you let VDJ close completely (save your database) before shutting down the computer
geposted Mon 02 Apr 07 @ 6:04 pm
That's my point, I DON'T shutdown the computer, and I recurse, and still when I change to another folder then change back to the scanned one, there are some left w/o the previously scanned bpm and minutes length.
geposted Mon 02 Apr 07 @ 7:29 pm
Sounds like a corrupt database or something.. There is a tool called Auto-VDJ Database Backup. Maybe it works...
https://virtualdj.com/addons/view.html?type=tool
Good luck!
Good luck!
geposted Mon 02 Apr 07 @ 8:55 pm
the home edition user one doesnt exicute, and I cant get the one for pro user
:( Booooo
:( Booooo
geposted Tue 03 Apr 07 @ 4:08 am
