Forum: Old versions
Topic: Fix Stuttering
djzim4PRO InfinityMember since 2006
I have a question about stuttering.
When I open Virtual DJ, I play the first song on the left side. As the song comes to an end, I start the second tune on the right side. When the first song ends, it causes the music to stutter, speed up, turn off, then start again. It will do this for the first 3 songs then it will stop.
But it happens again. After about an hour of use it will repeat the same steps.
I also find that when I load a song that is over 7 minutes long, when it is loading it will cause the other side to stutter, and sometimes stop the tune all together.
Any ideas on how I can fix this?
Thanks
DJ Zim 4
geposted Tue 03 Apr 07 @ 12:50 am
*Check max-load setting in VDJ config.
Is it set to 15 or 30 mins?
You need to load the whole song into ram, to work good
geposted Tue 03 Apr 07 @ 6:02 pm
