Forum: Old versions
Topic: Slow Loading of MP3
It seems like it takes forever to load a MP3 onto the decks, it takes maybe 2 minutes for the complete Wavelength to load on my Mac. I am running OSX 10.4.9 1.5 Ghz 1GB Ram, should not be this bad,I have changed codecs between the default and the Quicktime with no change in this.... Any Tips?
geposted Tue 03 Apr 07 @ 8:05 am
Does it loads a video much faster?
No, its worse, I loaded a Divx File which my PC Loads in seconds and the Mac is going on 3 minutes building the waveform for this file. Not to mention it cant even smoothly play the video... is anyone having this problem on the IntelBased Macs? Better yet am I the only one having this problem on my PowerPC? Any help wouldbegreat..
Frustrated...
have you analized these files?
Yes I analyzed the files and still no go.... its seems everyone on here is using a Intel Mac, I have a Powerbook, is this the problem, its a 1.5 Ghz, should not be a problem.... I am disappointed in this because it takes too long to load a song, I cant get an entire song loaded by the time the other has ended.
After you load a video, the mp3 load is intentionally slow...
this is to prevent skips on slower systems.
On a PC you can turn this feature off in registry (if you have a good enough PC).
I bet you can do this on MAC too, just need to figure out how.. ;)
Dev Team will probably reveal that ...
This is everything... I just timed it using that neat feature on the clock where its lets you change from the clock to the timer.... Took 10minutes not exageratting ...exactly 10 minutes to load a 5:30, song.... how is this supposed to work... song is MP3 format, works fine in iTunes and emmhmm...Serato
10 minutes to load is not what I was talking about ;) lol
THAT is some error at your mac install, or a bug..
Noone else have reported such, so try a reinstall.
The slower load when playing videos, is hardly noticable...
So nothing like 10 mins...hehe
