Topic: exact size of xp-10
hello
i'm thinking about buying two xp-10's, but i would like to know the exact size of them to see if i can modify my flight case
thanx in advance
geposted Fri 10 Sep 04 @ 1:13 pm
thanx (bedankt)
and ???
(i know i'm not very patient)
indeed you aren't :)
anyway ill explain by this picture :
http://members.home.nl/psychic/XP10_measures.jpg
I've "drawn" the top of the XP10 aswell al the front view,
look at the earlier posted pics...
The measures for it are in CM. Since you want to make them flightcased I also put the ammount of space you need to leave open for the plugs and cables. The cables are placed 1 to 2 cm height from the "ground" so you could cut that part out of the flightcase or foam. This means you need to cut a square 2 x 7,5 to make room for the cables. I would recommend to make the bottom part of the case no higher than 3,2CM since you need to be able to move the jog. The top part needs to be 1,2CM minimum.
Have phun.
the square should be 1 x 7,5
thanx a lot,
you did some great drawings
you make me a happy man because IT WILL FIT
The xp10 is 8.75inch x 5.50 inch x 1.50 inch this is as close as you want to get .
