Forum: Old versions
Topic: Autosave not working
What can I do? this is VERY annoying.
geposted Fri 06 Apr 07 @ 11:04 am
Please be more specific... What do you think it should be doing? And when?
topic
when i scan songs then close my software it says "saving database" and it remembers your favorite folders, the bpm, time, etc...
well mine doesnt remember any of that when i reopen the software.
it is a pain.
any ideas?
Create a Save_Database shortcut and use that, never never never just rely on it when DJ is closing. Try that and let us know.
What O/S are you using? XP?
i don't know what this means...
and i am using XP
thanks
charming,
go to your VDJ folder. How many internaldatabase files do you have?
If you have more than one file, is there one called internaldatabase.xml and another one called internaldatabase(your_name).xml?
If so, what size are they?
Create a Save_Database shortcut and use that, never never never just rely on it when DJ is closing THIS MEANS go to keyboard shortcuts and look for Save_Database, then assign a keyboard shortcut to it and instead of just closing VDJ select this shortcut first which will save the database.
I see, thats a good tip, but it didn't solve my problem.
Phenryll wrote :
charming,
I only have 1 XML named "Virtual DJ Database" it is 1,058kb
