Forum: VirtualDJ Skins
Topic: Making a skin
I really ant to make a skin but have read the topic and it just seems like gobbledegook.
Is there a simple explaination?
Is there a way you can modify existing skins (just the picture) and it still work with the existing xml
Basically I want to use dannydazzlers CDJ1000's picture and make it work with the existing CDJ1000 xml.
Can I do this simply
geposted Fri 06 Apr 07 @ 1:33 pm
This sounds simple, but will only work if all you are doing is changing colors of buttons.
Try to read an XML file, then refer to the guide to explain what each bit is doing.
eg,
<button action="play_pause" chan="1">
this defines a button, with the action of play or pause and activates channel 1 (left deck)
<size width="32" height="24"></size>
defines the size to be 32 pixels across and 24 pixels down. the </size> at the end tells the script this is all the information for size.
<pos x="129" y="214"></pos>
tells the program where to place the play button
<up x="0" y="1040"></up>
tells the program when the button is up (not pressed) to display the area of the image file starting at these co-ordinates (0,1040)
<over x="33" y="1040"></over>
gives the position of the area to be displayed when the mouse cursor is over the button area
<down x="66" y="1040></down>
gives the position of the area to be displayed when the button is pressed
</button>
tells the program this is the end of the button definition.
Hope this gives you a little more understanding of how the XML file relates to the BMP image.
Mykel
I mean can you take the bmp file from one of the new skins and tune the xml file so it works on VDJ 3.4 because as I explained in my maoning post I have no need for version 4 because my version 3 is just right for me but I seem to be losing out on the new skins. I understand the "no liscence users" not being able to get their grubby mits on them but why should the rest of us miss out jst coz we dont have all the latest gadgets.
Yes, you can remove the 4.x elements from the skin XML, like songpos waveform="yes" element and change rhythm to the old style of this setup.
I am not 100% sure how much you will need to change, but I wish you all the best,
Mykel
How am i going to do that if I can't download the skins in the first place.
I understand what you are saying but I need the skins to try it. Can you help me out............please
I wish I were able to send you skins, but I have to respect the authors of the skins and therefore cannot send. You can contact authors directly and request skins.
(as I am only a co-author of any skins (and not the originator) I am unable to send any of the skins I have been involved in the development of.
Upon the launch of the skin-master.co.uk site See thread here, you may be able to get access to some skins from there though.
Mykel
OK
Thank you Mykel
