Forum: Old versions
Topic: maya external mixer skpping
hey guys,
I used my Maya 44 usb to connect my laptop to 2 channels on an external mixer
I selected the necessary configuration in VDJ, connected all the cables correctly and got the sound to come out of 2 seperate channels.
Problem is, every 15 secs or so the sound/tracks would skip in VDJ which was audible in the external mixer.
I think its something to do with the latency? Which settings should i change to avoid the skipping?
My laptop is fairly decent, 2.8 gig, 1 gig ram, enough HDD
Any ideas?
Cheers
geposted Sat 07 Apr 07 @ 6:10 am
no one? :(
How about telling us what you have VDJ set to in the Performance tab of the config? And What your MAYA Control Panel config settings are? You may have things set to high? Also, is the Latency set to 'AUTO' in VDJ? If not you could start there.,
