once in a while when i hit the left play button it will
stop the track on the right side,
turn on the beatlock, and
start effect 1 and 3 on the right side.
it's like it overloads and goes nuts. i'm not sure why it does this. any ideas?
geposted Fri 10 Sep 04 @ 11:15 pm
hi
i ve ur same problem from long time!
i posted in the italian forum but at the moment nope good answer.
i tried to upgrade my system from 256mb to 512mb (as recommended)
as processor im ok, ive got P4 2G ... so all configuration is ok, but i still have that problem.
clearly i ve just upgrade my firmware (HDC031G) and program version at the lastest i can download (1.09).
Firmware too is the lastest (v34)
helpppp!
(im sorry for my bad english)
helpppp!
geposted Sat 11 Sep 04 @ 12:42 am
i think you have to change the hconsole-mapper.
geposted Sat 11 Sep 04 @ 2:57 am
haha x-frag i have the exact same setup as you. 512 running p4 2.0. btw i did try remapping it. it still happened. sad sad...i'd really like for this feature to work properly...i noticed also that the lights dim a little here and there. kinda funky lol needs more power!
geposted Sat 11 Sep 04 @ 6:30 pm
Maybe it's not getting enough power through the usb port. Especially if it's on a usb hub without it's own power this could be true.
geposted Sun 12 Sep 04 @ 7:38 pm
IoI
anyway that problem comes out just if i do stop & play for x time, expecialy if i put before play a loop of 4/4
well i did try from the dj console mapping to create a new conf without assign any key;
well at this moment (also if i didnt test so long) it seem to dont stop any more the left turntable, just like u "the lights dim a little here and there" :P
ciao
ciao
geposted Mon 13 Sep 04 @ 1:56 pm
hi,
You must change your dj console. Hercules has changed me two times my dj console because it had the same problem you have.
I think there are a lot of people with this problem.
If you want repair it by alone, here there was a post about this problem. If your dj console has a warrancy period send it to hercules and they will change it.
regards.
JB
regards.
JB
geposted Tue 14 Sep 04 @ 12:49 pm
hi again,
you can read this post
https://virtualdj.com/forum/display.html?topic=6249
geposted Tue 14 Sep 04 @ 1:27 pm
hello and thank you,
i just bought a usb hub with external supply but itnst the problem so i think is in the way u explain.
.... but, did u revolve ur problem?
u didnt write if u sucessufull to resolve that by the operation u linked.
c u
rob
c u
rob
geposted Tue 14 Sep 04 @ 9:26 pm
re ciao all,
maybe i got it!
i ve tried to follow the step show in the link, but my prob was different;
the false contact was in the step 2:
1) retourner la console
= turn the console around
2) enlever les caches plastiques (5) pas celui du mileu ya rien
= take the (5) plastic bits away (there is nothing behind the one in the middle) ------> here!
i just cover with a piece of light paper all 5 screw behind the plastic bits, just to stop the false contact.
now it seem work correctly, just installing the lastest console driver and choosing from the "dj console mapper" "default" light here n there
anyway.... yeahhh
having fun
rob
maybe i got it!
anyway.... yeahhh
having fun
rob
geposted Wed 15 Sep 04 @ 3:39 am
