Hello i have dj cosnsole mk 2 ...when i start virtual dj and play the track :gain button dont work right if i choose 16db on gain there is no change ...if i turn high med or bass it also doesnt work right ... but in winamp the sound is great in virtual dj not good and i have new drivers and also update my software ..
Where s the problem ?
Thanks a lot
Thanks a lot
geposted Sun 08 Apr 07 @ 4:28 pm
Just upgrade to VDJ 4.3 from 4.2.1 and now my MK2 will not cross fade. Audio cross fader does not work at all left or right decks push play and both decks on at the same time. Looked in the config and everything looks good. Going to delete the old MK2 drivers and install the new drivers from them see if that works if not I'll just go back to 4.2 I will be trying to fix it now!
If anyone has this happen to them let me know how to fix this.
Thanks!
Thanks!
geposted Sun 08 Apr 07 @ 7:24 pm
Well some how the cross fader was set to disabled. Don't how that happen but it did maybe when i upgraded to 4.3 from 4.2r.1 but all working now! The only thing not working is the Mic input on the MK2
geposted Sun 08 Apr 07 @ 8:40 pm
I fixed the problem :)
I just Disabled LIMITER :) thats the problem of sound ....
geposted Mon 09 Apr 07 @ 6:02 pm
I had a problem .. i have the TCCD and the TCV, but when i use the hercules with the TCV no problems.. but with the TCCD OMG a lot of problems, sounds like scratching and slowly and no pitch, some one knows why ¡
geposted Thu 12 Apr 07 @ 1:48 am
A lot of CDJ player have problem with MK2, check info in my blog https://virtualdj.com/blog/cioce/?category=2
TITLE: How to connect two CDJ player into the inputs of Hercules MK2 (lower down the input volume value to delete the distortion)
geposted Thu 12 Apr 07 @ 12:03 pm
