Forum: Old versions
Topic: how works with my 2 sound cards ?
Hello world,
I have a laptop and Virtual DJ 4.1, i have bought a second usb sound card and i would like to use the two card at the same time. I want the first go to speakers A and B, the USb one for headphone to listen A and B all the time if the volume is off for the speakers.
2 years ago I have 2.1 and the menu was very simple in another computeur but in 4.1 it seems to be very difficulte, i have tried many case but i have the B only in speaker, the A for headphone but no sound in speakers....
can you help me, her the screenshoot of ma possibilities:
http://img362.imageshack.us/img362/7892/virtualdjsy3.jpg
thanks a lot
geposted Sun 08 Apr 07 @ 9:40 pm
for this you need to choose
inputs: none
outputs : headphones
card: 2 cards
main : first card
headphones : seccond card
you may need to then assign channels , to your choosing.
however you need 4.2 to use this correctly so i suggest you update your "demo"
hope to see you with us soon :)
hi, almost works, i have all but with the headphone i have a probleme: i can heard only one side, i have tried to swicth my plugs and the master output but its the same result :(
excuze me its solved, forget to switch on buttons A and B for headphones lol
i have the atomixmp3 software but i'm facing 2 pbm, first i cant prelisten to a song fromthe second platine in my headphone before mixing it into when playing the first one to the public, this is how i figure the sound configuration from the software, i choose 2 sound card for the headphone out put.
my second pgm is that i dont have any choices than the default when trying to change the skin of my atomix, i downlaoded some from the skins file but nothing so far can u help me please?
please add your serial to get the latest updates.
how can i add my serial , how can i do this, u talking about my serial number? please show me how to do this please
i got the atomix v.2.3 this not the latest? if there is any help me get it plz
