Forum: Old versions
Topic: How to automix
Is Automix supported on this release? Cant figure it out..
geposted Mon 09 Apr 07 @ 4:05 am
Yes ... just tried it. :-)
Are you refering to the "autp-pilot"? When you just load a playlist and it plays and syncs all the songs by itself?
Yes . auto pilot.
I think i got it to work.. Can you set the time when it start and ends somewhere?
A couple of time It didnt load up the next song. Not sure why?
I dont think so .. You mean like it starts at 430pm and ends at 5pm ?? If that's the case, I don't believe so. It tells you the duration, so you can keep an eye on the time.
No, what i was trying yo figure out how AUTOPilot worked.
Does it start at say 10 seconds before the track ends? Then start to automix?
Its probably just a General VDJ question.(not MAC related)
Ok ... You can adjust the times in the Settings I believe... You drag a song to the playlist and hit automix... But yes there are timings for that and they can be adjusted.
