Forum: Old versions
Topic: Audio quality/levels problem
Hi Guy\'s wonder if you can help me please. I am using the lastest version of VDJ, its so stable you gotta love it, but im having audio issues. My audio level are very low especialy when using video (VOB) files (auto gain enabled), also if finding there is bad distortion with little bass and the mid/high screaming. when playing the same file back through windows media player is sounds like it should. Im using the folloing -
giga port ag,
Intel CPU Core 2 Duo E6300 1.86GHz
Geil® Ultra DDR2 2.0GB
500 GB Western Digital Caviar
Window Home
Many Thanks for reading
geposted Mon 09 Apr 07 @ 1:22 pm
Hi keith try to change the decoder in the opcions menu for the same one as windows media your using.
hope it helps
Out of curiosity, what does the "windows media" codec setting do that the VDJ's "video codec" may not be doing. As I have tried both with wmv files that play on windows media but never on VDJ and I HAVE TRIED both codec settings?
Any help here please?
