DAC2 - why isn't my green like on? in the remote tab. i think the controller will not work fully until the green like come on. my bend buttons are not working as well.
geposted Mon 09 Apr 07 @ 5:43 pm
Download The drivers from here:
http://pcdj.com/support/drivers.asp
Unzip the files to a folder.
When you plug the USB cable into the dac and the Found new hardware window comes up, use the wizard and install the drivers by using the advanced install and chosing the folder where you unzipped the folders.
Then resart the comp - and open VDJ select DAC 2 in remote TAB and select auto-detect.
Close and restart VDJ.
The DAC 2 Default settings suck donkey shlong.
Download a mapper either the one written by PERN or CSTOLL.
Download from here:
https://virtualdj.com/addons/view.html?type=tool
Then read the readme files and away you go.
Download from here:
geposted Mon 09 Apr 07 @ 8:12 pm
What if I already have a fully working DAC2... of course when I'm using PCDJ FX. Should I still redownload it and install it?
geposted Mon 09 Apr 07 @ 10:53 pm
Try a mapper then - the buttons should work then.
geposted Mon 09 Apr 07 @ 11:18 pm
Can I use PCDJ FX and Virtual DJ on one machine using same DAC2 controller? I will not be using both at tha same time.
geposted Wed 11 Apr 07 @ 12:21 am
first let me thank Marcel1 for the support
Yes, which program are you mainly going to use. if it's vdj then activate the controller first in vdj.
im new to vdj and im using vdj first, channel 1 & 2. if i have any problems i switch to pcdjfx on channel 3 & 4. then go to my config and test the controller.
geposted Wed 11 Apr 07 @ 12:35 am
You have it working then?
Good to hear.
Good to hear.
geposted Wed 11 Apr 07 @ 12:58 am
how do i get into browse mode with a dac2
geposted Wed 11 Apr 07 @ 1:34 am
Depends on which mapper you downloaded.
With cstoll's (I use that one) You press SHIT while turning the inner jog dial.
This will put the player's jog dail into browse mode.
Also - check out the readme file with the mapper it'll tell you to enable browse mode in the external tools tab under EFFECTS.
geposted Wed 11 Apr 07 @ 4:52 am
OH Man I just read my post - PRESS SHIFT, SHIFT , SHIFT - dammit -
Don;t press the shit button. - not pretty - not pretty at all.
geposted Wed 11 Apr 07 @ 4:53 am
hi wendell81
which soundcard you use to run both the programs? isn't there a driver conflict?
regards
regards
geposted Wed 11 Apr 07 @ 5:57 am
i use a gigaport sound card. remember that i can only use the controller for on program at a time
geposted Wed 11 Apr 07 @ 4:14 pm
