Forum: Old versions
Topic: Easy question...
I think I know the answer to this, but my tech support guy who makes my external soundcard (Presonus) wanted me to ask..
Does VDJ have a main (master) volume output fader to control how much volume is sendning out from the program?
I have VDJ on "always play 0db" and my signal is coming hot frm the Presonus. It is not easy to adjust each line signal db in Presonus so he wanted me to ask if the software had this feature.
Thanks,
B
geposted Mon 09 Apr 07 @ 8:08 pm
There's a master output fader, but for some reason it's not on the default skin.
I use VMIX 5.2 and it's on the top most panel, above the waveform, there. But I guess there's other skins with it on too if you need it but don't fancy Vmix.
Hope that helps :)
HI,
I also use vmix 5.2 - does that fader work even if I am using timecode CDs and an external soundcard?
Works for me using a maya 44 usb in asio mode (same mode as you use for timecode), but I don't actually use timecode so i'm not totally sure about that one!
Thanks Andy- That is exactlw what I needed- I think this will help lower the hot signal my external soundcard is sending to the club's mixer.
cool.
appreciate it.
B
No probs mate. :)
