Forum: VirtualDJ Skins
Topic: sni snif
no good and wonderful skins for home edition user...snif snif
geposted Tue 10 Apr 07 @ 4:29 pm
Which skins do you want then?
When I was useing Home edition I really like the Dennon 1800 skin. Simple and well laid out.
snif snif ok snif snif snif snif how about ..... you buy the Vdj pro program like i did .
Then the skins will be free to you.
The program you got was free with the Hercules Mk2.
You will need V4.0 or V4.3 the newer skins will not work with home edition which is Version 3.4
so you will need to buy the Pro Version of Vdj to get the newer skins snif .
DJ FORMAT
simply home edition skins are for v 3
pro skins are for v4.
which only pro users can use,
you may wish to take the
discount offer and upgrade to pro today i did it this way and have been delighed ever since
kind regards
simon.
