Hi All,
I have a Dell XPS Dual 2.66 Core Duo with 4GB of RAM and a Nvidia Geforce 8800GTX. I have tried everything to get it to output to my connected TV. I have the Video card driver set to Span mode and the dextop is exteded onto the TV I have connected to the S video output. But when I launch Virtual DJ and go to the Video config panel there in no TV putput to be sellected only window. PLEASE HELP!!! I have been trying for days. Thanks.
geposted Tue 10 Apr 07 @ 4:43 pm
zanzibart
i'll try and help until someone with more technical ability comes on line, i have a lappy with n/v go 6100 and it works a treat, before you attempt anything make sure all necessary cables are hooked up before you switch on, when you open up go to nvidia settings make sure you have it set at dual mode, then on opening vdj go into configuration open up video tab, near the top it says tv output, left click the drop down window and chose nvidia,close configuration and hopefully if i got it right you should have a picture on your screens, if i did'nt your on your own lol, sorry if it did'nt just be patient someone with more experience will be along in a while...Tayla
geposted Tue 10 Apr 07 @ 6:31 pm
Hi Tayla,
Thanks you the reply. I have done all of this. The computer is booted in Dual/Span monitor mode but when I start VDJ the video card's TV output does not come up. I have reinstalled the driver and VDJ. Still no luck.
geposted Tue 10 Apr 07 @ 8:09 pm
nearly forgot
you know when you breakdown and the rescue fella comes along he always asks "do you have any petrol in" well have you got the latest edition of directx drivers (feb 07) if not put them in before you do anything...Tayla
ps just caught your reply when writing the above have you checked tv settings and options box in video tab, sorry if that don't work you will have to hang fire until more experienced guys come along...goodluck
pps have you tried in
video output
activate - tick
use hardware acceleration - tick
in options
linked crossfaders - tick
activate on load - tick
Tayla
video output
activate - tick
in options
Tayla
geposted Tue 10 Apr 07 @ 8:10 pm
How can I tell if I am in fact running the VDJ Pro? If I have been given the Home edition then the Tv output is not available on that version and that would be my problem. Othe than that I have tried everything under the sun, my next move will be to do a full reinstall of XP etc. Any would be appeciated.
geposted Wed 11 Apr 07 @ 4:11 pm
could anyone else step in here to help as i've given zanzibart the best of my limited experience...Tayla
geposted Wed 11 Apr 07 @ 9:21 pm
Hi Zanzibartt,
Looks like you've got a problem here that there isn't an easy answer to. I'm sure lots of people have read the thread. I know I've been around here for over a year and I can't remember anybody having this problem.
https://virtualdj.com/contact/
If you go to here you can get in touch with the service department i think.
Good luck. :)
Good luck. :)
geposted Thu 12 Apr 07 @ 1:05 am
Hi All,
Thanks to the couple people that were able to help. I finally got it working. It took a complete reinstall of the operating system, drivers & VDJ. I hope this doesn't happen to anyone else it is a real pain in the butt.
geposted Thu 12 Apr 07 @ 4:54 pm
zanzibartt
glad i could help with my limited knowledge...Tayla
geposted Thu 12 Apr 07 @ 6:28 pm
Glad you got it working mate. Strange the things that can happen sometimes!
geposted Fri 13 Apr 07 @ 2:18 am
