started a disco using virtual dj 3.0 any advice for downloads using vista on my laptop looking for work at the moment spent a fortune on lights and equipment but i bet it will be worth it in the end please give me some advice new to this
geposted Tue 10 Apr 07 @ 8:57 pm
What downloads are you looking for? What is it you want to do? If you want to do video, you will need a good video card, with it's own ram.
geposted Tue 10 Apr 07 @ 10:17 pm
And you need VDJ Pro for sure ;)
For video, get Geforce 7600Gt with 256MB DDR3, no less.
geposted Wed 11 Apr 07 @ 2:15 am
please try the ,latest demo it carries many important updates , hope to see you as a pro user soon
kind regards
simon
kind regards
simon
geposted Wed 11 Apr 07 @ 6:18 pm
thanks for your reply need good advice on how to get myself recognised as a mobile disco have downloaded latest software on your trial period awesome dude
geposted Wed 11 Apr 07 @ 8:16 pm
where are you located?
geposted Thu 12 Apr 07 @ 2:58 pm
sorry for being late for responding my location is the midlands Tamworth if that helps
geposted Sat 14 Apr 07 @ 8:36 pm
Need some advice on any external devices for laptop so i dont have to use my laptop as a mixing station just use it as the main source for music and use the external device to plug in earphones and the likes for mixing music
geposted Sat 14 Apr 07 @ 8:41 pm
check my blog for info on harddrives
geposted Sat 14 Apr 07 @ 8:49 pm
cheers mate....
geposted Sat 14 Apr 07 @ 8:53 pm
I like the look of the dj console mk2 would this be good enough for a mobile disco and does it plug in to your usb2.0 port with software to load
geposted Sat 14 Apr 07 @ 8:58 pm
yes it is a great card and controler and comes with virtual dj home edition :)
geposted Sun 15 Apr 07 @ 12:23 am
