Forum: Old versions
Topic: Question for any teamer VDJ
Does the MASTER volume on the top of my skin (vmix 5.2) have to always go back to 100% everytime I open the skin?
When I move it to say 75% to lower the main out volume of VDJ, then close the skin and re-open- it is always 100%.
Is this normal and does it have to be this way?
Almost every setting stays the same when you close VDJ except this.
thanks for help.
B
geposted Wed 11 Apr 07 @ 11:37 pm
All SKIN based settings go back to defaults at each launching of VDJ
-- Volume 100% - Master and per channel
-- Gain 0.0db
-- Headphone crossfader
Anything that is managable in the Config as well as by the registry settings are the only things that stay the same from it's last session setting.
thank you C
