As a DJ who scratches;
I'm sure the wheels are too small to do a great job for scratching.
You need to have that larger circle so you can keep your cuts small or do a long slow rewind.
Plus the wheels are too close and give your arm and hands less range of motion.
I am planing to get the VCI-100 ASAP but the second they put out their sound card I'm going to run it with my DZ-1200s, that should be hot.
geposted Sun 22 Apr 07 @ 7:28 am
I don't scratch myself, but you may be right. The only scratching I've done was with vinyl and I would probably use TCV if that was my scene. But I'm sure and hope that there are some talented people who will prove me wrong. If I started scratching at my gigs they's call out the men in white coats ;-)
geposted Sun 22 Apr 07 @ 2:12 pm
