Forum: Old versions
Topic: NUMARK CUE/TOTAL CONTROL SOFTWARE VERSION
Can anyone tell me what the specific functions of the 'LE' version of Cue that comes with the Numark Total Controll(er) please? I don't intend to use video mixing, so I'm only really concerned to find out if you can split the outputs like the Pro version, so I can run them through my external mixer seperately.
I don't really want to buy one to discover that I still need to fork out another £200 on the Pro version...
Plus, can you use VST effects (like echo) on just the output of the sampler?
Thanks!
geposted Thu 12 Apr 07 @ 6:54 pm
it is same i belive as the console edition of virtual dj
comparison
Ok not looking quite so cool all of a sudden then... How can you cue up the next track then, as Hercules mk2 has a dedicated HP socket (w/split cue facility)? Can it be selected to output from the soundcard seperately? If not this would make the Numark a lovely controller but less useful than the Hercules without shelling out near £450 in total...
It would be a shame if that is so, as I don't think I can afford that much, and am quite convinced I need the Pro version to output channels seperately. I'm just hoping somewhere near me will decide to stock them so I can have a go and test it all out for myself!
Thanks again.
