would it be possible to use the following to act as ASIO sound cards:
creative audigy eax hd
creative audigy eax hd sb1394
i have one of each, the only difference being the sb1394 has a firewire port
thanks
james
ps: what does ASIO mean?
thanks
james
geposted Fri 13 Apr 07 @ 12:02 am
ASIO (Audio Stream Input/Output) is a protocol for low-latency digital audio specified by Steinberg.
ASIO provides an interface between an application and the sound card. Whereas Microsoft’s DirectSound is typically for stereo input and output for consumers, ASIO provides for the needs of musicians and sound engineers. ASIO offers a relatively simple way of accessing multiple audio inputs and outputs independently. It also provides for the synchronization of input with output in a way that is not possible with DirectSound, allowing recording studios to process their audio via software on the computer instead of using thousands of dollars worth of separate equipment. Its main strength lies in its method of bypassing the inherently high latency of operating system audio mixing kernels (KMixer), allowing direct, high speed communication with audio hardware.
as to those cards im not sure if they are asio
however you can use asio on most cards
using the asio4all.com driver
which forces asio on wmd cards.
geposted Fri 13 Apr 07 @ 12:37 am
So as long as the soundcards are ASIO compatible, it can be used with vdj??
geposted Sat 14 Apr 07 @ 10:55 pm
