abitility to have 2 instances of virtual dj. check.
ability to have [active deck on virtual dj 1] beat match with [active deck on virtual dj 2]
or some kind of a plug in.
thanks,
DJ Shahar
www.djshahar.com
thanks,
DJ Shahar
www.djshahar.com
geposted Fri 13 Apr 07 @ 6:56 pm
yes in options enable local syncronisation
geposted Fri 13 Apr 07 @ 7:03 pm
Already available in VirtualDJ pro !!!
geposted Sat 14 Apr 07 @ 4:14 pm
you are talking about "network"
i mean. 2 instances on the same laptpo.
geposted Wed 18 Apr 07 @ 6:08 pm
Set VDj in this mode
geposted Wed 18 Apr 07 @ 9:24 pm
yes i see.
i've tested it out.
here is my suggestion.
click on 'beat match' to match with other side on current deck.
right click on 'beat match' to have a dropdown menu (similar to effects) asking which deck of which instance to match. both bpm and beat.
how about that?
sounds amazing on this side.
DJ Shahar
www.djshahar.com
i've tested it out.
how about that?
DJ Shahar
www.djshahar.com
geposted Wed 18 Apr 07 @ 11:25 pm
