Forum: VirtualDJ Skins
Topic: Cue Default Skins In Widescreen 1280 x 800
geposted Sat 14 Apr 07 @ 12:25 am
Cannot I download it yet by Mac?
There is a problem with the installer for Mac. This is being addressed and should be fixed soon
Good Skin
But No Downloads ?
hi my name mohamed from egypt
i like this weeb and all program
and music
thx
senba
FORMAT,
I saw the screen shot with what you did to the "Cue" skin. I been needing this skin at 1280x800 for awhile. I attempted to change it myself using notepad .xml editor but honestly, I was guessing at which values I need to change to the .xml and still cant figure it out. All I want to to learn is how to take a skin and convert it to 1280x800. I thought all I needed to change was the Height & Width in the .xml and .bmp but I guess not. I always got an error saying: "error in line 0". Wish I knew ALL the exact places to go to edit the skins dimensions. By the way, the skin I was trying to edit was "Cue".
Great work-
DJ_Eslam wrote :
Good Skin
But No Downloads ?
its for pro users only
hope to see you with us soon
goodddd thanks you veryy
